Okay soweit hab ich jetzt alles verbunden Auto ist gekoppelt aber ja das war es dann auch Lizenz erworben Treiber installiert
		Besteht Interesse an Infos zu OBD2 Adapter und Software?
			Okay as far as I have now connected everything. The car is paired, but yes, that was it. I bought a license and installed the driver OK, what do you wand to change? Activate traffic sign recognition (TSR)?
			Also meine Frage ist jetzt was hat es mit der Hex Tabelle aufsich usw usw
 Habe auch diesen Wert gefunden und dann ?
 009B 0000 50FB
 Also ich lasse es erstmal aufjedenfall funktioniert alles kann alles auslesen aber der Rest ist mir zu heiß
			yes Tsr
			yes Tsr Once connected with the car and forscan in the status of your previous picture: - Press the "configuration and programmin" button (at the left side of the screen, the 3rd starting from the bottom). Then select the entry that says "FSC Module Configuration (Data As Built) and hit the "play" button that is at the bottom left.
 - If the software tells you to change the position of the OBD adaptew switch, do it). Also, the software will open a warning dialog telling you that it is risky to change as built configurations if you don't know what you are doing. Press OK and let the software to read the configuration
 - A new screen will open showing the current values of the FSC module chains. I want you to read and note the current values of chain 706-01-02 and report them to me. Most likely you should have this: 009B 0000 50FB . Please confirm and I will tell you the new value that you need to input. Meanwhile, stop the service and cancel the operation so you do not make any changes.
			OK, I did not see your previous message whare you confirm that your current value is indeed 009B 0000 50FB. All you have to do is to edit this value directly and change the last four digits: 50FB -> 40E8. Once done, hit the "write button at the right side of this module. The software will ask you to turn off ignition and to turn it on again. Finally, once ignition is back on, press the" stop "button at the bottom left , and disconnect forscan. You are done and the TSR should be working
			There ist no write button
			The one that is at the right of 706-01-04, it is the write button for the entire block
			Yesss yesss Thank you very Much Baldo Mero great great
			 Enjoy!
