Ich versuche, mir den Samstag frei zu machen und wäre dann sehr gerne dabei. Definitiv weiß ich aber erst morgen...
Beiträge von Chipmonk77
Wenn der BS soviel Grip besonders im Trockenen zu haben scheint... kann es nicht sein, dass die verwendete Gummimischung sehr empfindlich auf kühle Lagertemperaturen reagiert
Beim AD08RS (ich weiß...
) wird ja z.B. explizit auf diese Problematik bei <20°C hingewiesen. Meine damaligen Parada haben die Lagerung im Keller auch nicht gut überstanden, hab ich sogar als Laie sofort bemerkt
Nur ein kleiner Denkanstoß ...
Bin gerade auf folgende Aussagen von Bridgestone bzgl. MX-5 gestossen:
HOW BRIDGESTONE DEVELOPED TIRES THAT TALK
"Mazda's done a very good job of understanding the customer," Mike Martini, president of Bridgestone Tire's OEM division, told Ars. Martini's company supplies the tires on the MX-5 Miata. "They understand their customers very well. Cornering at 1 g or more is not their priority. They do not want a supercar. Tailoring the tire's behavior at maximum grip is always a balance. The car manufacturers are under huge pressure to achieve improving fuel economy figures and also noise and grip. But in the Miata's case, any tangible goals are equal to and perhaps even secondary to communication."
"For the new Miata," continued Martini, "part of that was sitting with Mazda's chassis engineers early and often. They had a clear idea where they were heading with progressive tire behavior at and beyond the tires' tractive limits, and even more importantly, excellent communication during those moments and transients. We also worked with them on digital modeling. We can predict the variables pretty well now, so the suspension geometry, yaw rates, weight, roll stiffness, various force and polar moment perspectives, the effects of building outside tire loads, and the linearity of tire and steering response were all initially figured on computer. However, all of it must be validated in the real world."Da war Marketing aber wohl auch etwas involviert...
Habe mich für beide Termine eingeklickt...
Mein Augenzwinkern bezog sich auf die Entwicklung des MX-5 an sich... wenn man sich Entwicklungstagebuch und Technical Reviews dazu ansieht. Da wurde nicht viel vom Controlling geschweige denn Marketing vorgegeben, wie das bei anderen Herstellern der Fall ist. Einen Roadster in dieser Preisklasse ohne den Zwang einer „Plattformstrategie“ zu entwickeln und ziemlich freie Hand in der Grundkonzeption zu haben... davon können europäische Ingenieure nur träumen
Wird jetzt nicht weiter OT... aber ich denke, Du weißt wie ich dass sehe
Seit heute ist die Developer Build 2 von iOS 13 raus gekommen. „SlashGear“ berichtet von einer Möglichkeit, dass Profil und damit die Beta zu laden ohne einen Dev-Account zu haben. Man muss vom jeweilgen Endgerät den Download starten, nicht die ipsw-Datei laden.
Anbei der Link:
https://betaprofiles.com/
https://www.slashgear.com/ios-…dev-restriction-18580912/iOS 13 funzt nur ab iPhone 6s/SE aufwärts, mein iPhone 6 läuft damit nicht mehr
Habe aber gerade das iPadOS 13 geladen und es funktioniert problemlos... -
... Die Produktentwicklung ist immer ein Kompromiss und das heißt irgendwer wird immer unzufrieden sein.
Glücklicherweise sind unsere MX-5 Entwickler da noch schön kompromisslos geblieben...
Das mit der Schallführung im Bereich der Sicke beschäftigt mich auch. Ich werde die Anmerkungen von @Ulli und @Harkpabst zum Anlass nehmen, die Türverkleidungen doch noch etwas zu modifizieren.
Der dünne Plastik-Ring hinter den LS-Gittern kommt weg und der umliegende Bereich wird dann nochmal ordentlich gedämmt werden.
Berichte dann mal, was ich so schlussendlich so getrieben habe
Habe diese von Tomzz Audio bestellt:
https://www.amazon.de/tomzz-Audio-2838-002-Lautsprecherringe-Lautsp...
Sind 24mm hoch... und passen
Das Display ist das gleiche wie bei den CL/EL ohne Extras. Du wirst dort Kühlmitteltemperatur, Tankinhalt und Kilometerzähler mit 2xTrip vorfinden. Außentemperaturanzeige bin ich nicht sicher. Der Touringcomputer ist nicht vorhanden, und könnte auch nur mit den nicht vorhandenen Lenkradtasten bedient werden...
