Hier steht's (aus dem ND WHB):
Step | Inspection | Action | |
1 | VERIFY VEHICLE COLLISION
| Yes |
DTC B1206:00/B143A:00/U2107:00 [SAS CONTROL MODULE (STANDARD DEPLOYMENT CONTROL SYSTEM)] | 2016 ND Shop Manual
< Previous Next > < Previous Next >…
www.hexorcism.com
Für die Konfiguration eines Neuteils gibt es zwei Wege:
SAS CONTROL MODULE CONFIGURATION (USING READ/WRITE FUNCTION) [TWO-STEP DEPLOYMENT CONTROL SYSTEM] | 2016 ND Shop Manual
< Previous Next > CAUTION: NOTE: 1. Connect the M-MDS to the DLC–2. 2. After the vehicle is identified, select the following items from the initial screen of…
www.hexorcism.com
und
SAS CONTROL MODULE CONFIGURATION (USING AS-BUILT DATA) [TWO-STEP DEPLOYMENT CONTROL SYSTEM] | 2016 ND Shop Manual
< Previous Next > CAUTION: 1. Connect the M-MDS to the DLC–2. 2. After the vehicle is identified, select the following items from the initial screen of the…
www.hexorcism.com
Beide benötigen das Mazda Diagnosesystem.
